Key hole cover on drivers door, 2023 Pro-4X
295 views 6 replies 5 participants last post by  Dan T
#1 ·
I recently found the key hole cover of my '23 Pro-4X drivers door loose. Any idea what would have caused this, a piece fell off or a piece broke?
What was the fix?
Thanks
#5 ·
As of about a year ago, you were not going to find just that part - at least not in a matched color. Resist pulling toward rear as you open and it may mitigate some. Fronts are different from rears in how much wiggle there is (if curious). More detail here, but whole thread is recommended
As for the "rub", I'm not sure its limited to 22/23. In contradiction to myself, I apparently said:
Observation: my '24 has lube between handle and lock cover on front doors only. My '22 didn't have any.
