I took mine straight to the dealership but if you use and follow your chilton repair guid you"ll be home free.
He is in a tight situation. He is deployed overseas with his Frontier in a country that only has Navara's. He can't simply take it to the local dealership expecting a warranty repair. They are going to charge him and on top of all of that, the rates overseas are a bit extreme and that is why it will cost him almost as much as a new motor would.I took mine straight to the dealership but if you use and follow your chilton repair guid you"ll be home free.
I am pretty sure the t-state is good. Its dry where it mates to the block. I am about 95% sure its the waterpump seal. I think it got cut or something when i put it in the motor. I am going to take it to nissan today, and have them take a look at it and hopefully fix it. If i can get it fixed for 1k bucks or less i will be happy. If not, I guess i will be taking a loan from the bank or something. I got in too deep and no one around here knows enough about nissans to give me a hand. This is the first time i've ever tapped out of a job, I guess i cant wrap my mind around these newer engines.He is in a tight situation. He is deployed overseas with his Frontier in a country that only has Navara's. He can't simply take it to the local dealership expecting a warranty repair. They are going to charge him and on top of all of that, the rates overseas are a bit extreme and that is why it will cost him almost as much as a new motor would.
I know there is a gasket between the Tstat and the housing, is it leaking there?
Past that I would remove the Tstat and look around in there to see if you see anything out of place
After that, I would dis-assemble the front half of the motor again and basically start over and make sure you apply the proper amount of RTV to all surfaces needing it.
Side Note: Did you ensure that the RTV set-up before you added fluids and pressurized the system?
no doubt, the exchange rate sucks really bad. 3 more months and i will be back in the US. cant wait. :fantastic:700 euro is like 1.4k US so that is a bit of money but for your situation, its the price to pay.
This is the great thing about the internet and in this case, forums. It is people like you that post up your experiences and let others know what they may run into along the way. You go the step further and actually tell others what "tricks" will make the job a bit easier. This is why the forums are so valuable to DIYers.Also, here is a couple of things that i ran into for anyone who is going to attempt this. I used a 1/4 inch extension in the #1 piston to find TDC...I was 180 degrees off. take the valve covers off and ensure that both camshaft lobes are pointed up. I realized my mistake after i did both secondary chains, and tried aligning the primary chain and couldnt. nothing was binding when rotated the crank, but just a heads up. you dont need to take the oil pans off, but there are 2 bolts in the top oil pan that go in the timing chain cover. for you 4x4 owners the alternator sucks to get out. I would say you need 3 people to do this job, 2 for the mechanical work and one to clean RTV off EVERTHING. I think the only reason nissan uses bolts is to hold everything in place while the RTV sets. you can use a 15/16 wrench on the cams to keep them from rotating while you torque down the sprockets(figured that one out too late, i used a strap wrench and it sucked)....thats all i can really think of right now. If anything else pops up i will post it. This stuff might seem dumb to some people, but if i knew it going in it would have made the job a little easier.
