1 - 3 of 3 Posts
Hi everyone new member here just bought a nissan frontier 2007 4.0 6spd 124,000 miles king cab no warranty drove it 2hrs home and loved it rode smooth shifts great sounds great no rust but after getting home showing it off I went to start it up again and it sounds like it has a exhaust leak and only idles about 500-600 rpm idels ruff took it down the road and stopped shut it off and it started running fine again took it back home about 2mi shut it off back on again and same problem all over only thing I did before all this started was test the 4wd and everything worked fine.also no check engine lights or anything like that I can't figure it out any help would be greatly appreciated.
my 2008 has always idled low and rough as soon as it gets to low it speeds up slightly. Some members have had dealer raise idle speed. I am so used to it after 120000 miles that it does not bother me anymore. My truck is auto so may be different but if this describes your situation it may be normal.
If you get a tuner, i.e. Superchips, you can tweak the ignition timing and the idle...and get a little more power out of her, besides.
1 - 3 of 3 Posts
