1 - 7 of 7 Posts
I just went on vacation to the Southwest corner of Colorado to do some off-roading in my side by side. The truck performed flawlessly for the load it was hauling. We maintained a steady 10 MPG driving 65 MPH and hauling around 4500 lbs.
Entering Colorado:
Red Mountain Pass (11,018 feet):
Our campsite:
10 mpg seems respectable with the tow load
Rogue Admin
2007 LE 4x4 Crew Cab Long Box
Nice pics. If you are going to tow that much weight often, I would advise you to consider some air bags for the rear suspension to prevent your springs from flattening out
So within the next week I will be in a 16 SV 4x4. 4.0 .. towing my boat at approximately 1700 lbs. Relatively flat midwest interstate should I expect 12+ mpgs or so? Looking forward to this truck ownership!
DaBones, I'd say 12 to 13 would probably be conservative. You might see better. Zedbra's comment from above is from 2016 but still relevant, I have the Firestone RideRites mounted and they are great, some minor modding during installation but afterwards, zero hassle, zero maintenance and honestly with 22PSI in them, I think the truck rides better than it did stock.
I have a completely stock HD suspension otherwise, just the Pro4 OE uprated springs with OE Bilstein shocks, so that gives a good baseline before mods. I'm adding a 2" lift in the Spring and possibly another leaf in the rears.
I got 13.3MPG towing a 2500# boat from Tampa to Miami and back. I ran with the OD off.
So I finally test drove a 16 SV last night. I did see about 3500 rpms at 60 mph in "3" .. about 2250 rpms in D. Where should rpms be in D without OD?? Loved the truck and 4 wheel discs stopping power. Didn't love the steering but not enough to kill a purchase. What is the decked out model on these trucks?? Backup cam.. heated power seats.. etc.??
1 - 7 of 7 Posts
