My passenger side jump seat will not stay up. Apparently the added weight of the box on it's bottom makes it fall down. I feel certain I'm not the only one with this problem since Nissan has always had a problem with this sort of thing. The sun visors on my Murano are a perfect example. They just haven't figured out a way to make these types of things correctly or in a way they hold up to use.
Is there any way to tighten up the stops on the hinges that hold the jump seat up? The drivers side is fine, nice and tight but, it also doesn't have the added weight of the plastic box under it.
Thanks, Larry
Thanks, Larry
