1 - 11 of 11 Posts
I thought, I would share a list of info for the Jatco RE5R05A
“Share the wealth of knowledge and go as fast as you can.”
Jatco RE5R05A
Sonnax Valve Body Parts
http://www.sonnax.com/tech-articles/TASC-TIP-12-09.pdf
Oversized Pressure Regulator Valve and Boost Valve Assembly
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-01K :: Part Summary
TCC Control Sleeve Assembly
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-05K :: Part Summary
Cooler Bypass Valve Kit
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-07K :: Part Summary
Reverse Boost Valve Kit, Late Style
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-09K :: Part Summary
Reverse Boost Valve Kit, Early Style
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-12K :: Part Summary
"A" or "B" Pilot Valve Kit
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-13K :: Part Summary
TC Regulator Kit
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-17K :: Part Summary
Accumulator Control Valve Kit
Sonnax Transmission, Torque Converter, Performance, Driveline Parts :: Transmission :: 63741-20K :: Part Summary
Sonnax Torque Converter & HP Converter
http://www.sonnax.com/part_finder.ph..._only_sc=false
Omega Machine & Tool Co
Automatic Bushings
http://www.omegamachine.com/html/RE5...ushing-kit.htm
TransGo
RE5RO5A-HD2 REPROGRAMMING KIT High Performance
Nissan Reprogramming Kits
Transtar Industries, Inc.
Torque Converter Catalog
Pg 121 DA60
Transtar Industries, Inc. - Transmission Parts - Catalogs
Valve Body Manual
Pg 87, 88
AT Catalog
Nissan Catalog Pg 484
http://www.transtar1.com/catView.asp...444&strIDS=444
Valve Body Xpress
VBX-Guaranteed Remanufactured Valve Bodies
Alto Products Corp.
Alto Catalogs-- AltoUSA.com
.Save file
http://www.altousa.com/pdf/catalogs/oeiCatalog.pdf
http://www.altousa.com/pdf/catalogs/hiperfCatalog.pdf
http://www.altousa.com/np136.pdf
http://www.altousa.com/np127.pdf
http://www.altousa.com/np153.pdf
A good place to start is the TransGo RE5RO5A-HD2 REPROGRAMMING KIT. This kit will improve your shift tremendously. If anyone has the misfortune in burning up there transmission, then consider using an upgraded rebuild kit.
Alto 174758 Case Saver for the Nissan RE5R05A: B1 Reverse Brake Case Saver Kit 03+
The spline of steel separator plates can work back and forth to permanently damage the case, causing delayed engagement and ATF metal contamination. Alto Case Savers not only prevent this from happening again but allow reuse of the damaged case.
Alto OEI Original Equipment Improvement
Alto 174756 Input PowerPack Kit
Alto 174757 Direct PowerPack Kit
Install these PowerPacks to increase the six friction drum to seven or the seven friction drum to eight in the Input drum. For the Direct drum increase the five friction drum to seven or the six friction drum to eight frictions. This increased surface capacity will better handle heavy duty or hi-performance applications.
Side Note: These kits are made up of RED EAGLE Clutches and KOLENE Steel Clutches.
174903HPPWR-SK Hi Performance
Includes the OEI 174756 and 174757 PowerPack Kits and replaces the other stock clutch packs with RED EAGLE Friction Clutches and KOLENE Steel Clutches.
To sum it up:
TransGo RE5RO5A-HD2
Alto 174903HPPWR-SK Super Hi Performance
If you need to rebuild your Torque Converter
Alto 174782 Torque Converter
With everything else listed you will be able to replace any part necessary.
God Bless and good luck.
Tommy
PS I found a source where we can get the TransGo RE5RO5A-HD2 for 219.90 plus shipping pm me
Just an FYI for the auto guys, the transgo kit has been reported to be a great upgrade from both the Z/G and Titan owners.
Some Titan members have also done the install themselves so it can be done in the driveway/garage but you just have to be confident in your skills to drill some holes and to use a pick to remove/replace some small parts.
LevelTen had them build my tranny in my z after i destroyed it after only 3 days of being twin turbo and their products worked amazingly.
That reprogramming kit sounds tempting! Sorry if this is off topic, but arent you the guy who designed project giant mouth?
Wow, I’m impressed you have done your homework. Yes I’m the one who designed the PGM 90mm TB. Thanks for noticing.
Was looking for info on our tranny and stumbled across this over on ClubTitan
Nissan Transmission JATCO RE5R05A THANKS to RBsTitan
Good reading for those of you so inclined to actually work on the guts of your tranny!
One other thing I came across all in the service manual (2005-6), pg GI-47.
All models EXCEPT the LE use the RE5R05A, the LE uses the RE5R05E. Anyone know the difference?
I assume more "luxurious" shift points;-)
Is that PGM unit still available for Titan guys? What all went into that project?
PGM is no long in production. A few units pop up for sale during the year but they are quite expensive.
For what I have seen, they had to machine an adapter plate and then they had to do some kind of circuit card or something to adapt the drive by wire to work with the GM TB.
There is susposed to be another company looking into a large TB for the Titans. I believe it is an 87 thou, not a 90.
Did they see meaningful gains from it? It seems like a good product, I wonder why they decided to discontinue. Probably just not enough serious buyers... like most of the other expensive products for our trucks :).
Anyone installed transgo on their truck yet? Been thinking about this for awhile.
1 - 11 of 11 Posts
