Specs: Blue 2012 PRO-4X Crew Cab automatic
MODS
Gears and Axles:
M205 front diff
Cardone (Titan) CV axles 666238HD
Rear axle vent/diff breather mod
Drivetrain
XTP Intake Manifold Spacer (IMS)
Timken SP450701 Wheel Bearing and Hub Assembly
Fumoto F103SX M12-1.25 SX Series Drain Valve
Suspension and Tires:
Goodyear Wrangler Duratracs 265/75R16
Sway bar removed
Titan Swap
SPC Titan UCA's
PRG Radflo IFS 2.5's with 650# springs
Titan LCA's
PRG Heim steering
OME Dakar CS150R leaf springs
PRG Bilstein 5165 rear shocks with piggy-back reservoir
Spidertrax 1.5" wheel spacers
2" 2-degree steel lift blocks in the rear from HeavyMetal Suspension
Armor:
Rocky Road Outfitter's steel rock sliders
Hefty Fabworks aluminum skid plate full set
Hefty Fabworks aluminum front bumper
Shrockworks rear steel bumper
ARB rear differential cover
Exterior
Mile Marker SEC95 - 9500 lb. winch with synthetic rope
Century fiberglass canopy
Firestik Firefly CB antenna
Rally Armor mud flaps
CravenSpeed 4" Stubby antenna
Katana 9007 LED Headlight bulbs
Interior
JVC KW-V20BT DVD Receiver
Backup camera with infrared LEDs
President Johnny III CB radio
Front hood gas strut damper lift
Blue Sea System 6-circuit fuse block
USB 2.4A charging ports (front and back seats)
MODS
Gears and Axles:
M205 front diff
Drivetrain
Sway bar removed
Titan Swap
SPC Titan UCA's
Titan LCA's
PRG Heim steering
Armor:
Exterior
Interior
