1 - 8 of 8 Posts
Stupid question but where is the best place to place 4 jack stands on my 07 se. I am about to powder coat my wheels so I need to leave my truck on jack stands for a couple of days.
Sorry guys, tried searching but couldn't find exactly where to place them.
Thanks
anywhere on the frame is good as long as youre evenly balanced you shouldnt have a problem
my truck has arrows stamped into the metal for jack placement.
thats where i used them when i rotated my tires,
Be nice guys (to those who had their posts deleted).
I jack and stack under the control arms up front.
In the back I jack the diff. and put the stands under the axle on each side.
Remember to break your lug nuts loose before you jack.
Torque spec on the lugs is 95-100ft lbs when you put the wheels back on.
And criss-cross the lug tightening too.
I usually put two jack stands on each side of the rear axle and two where the jack points are on the front of the frame. The spots are marked by arrows just behind the front fenders. You can refer to your owners manual if you have trouble finding them.
If you don't jack under the control arms though and jack from the frame you have to go quite a bit higher to get the front wheels off the ground.
Either way works.
Thanks a lot guys...once again sorry. Couldn't find it in the search.
1 - 8 of 8 Posts
