I've been reading a lot of people talking about cams being improperly set up during timing belt changes even though the marks line up
It's impossible and here's why
With cams out of the picture for now, If the crank is aligned to the oil pump mark then it's guaranteed that 1 and it's corresponding cylinder are at tdc. Can either be compression or exhaust but since cams are out of the picture we don't know yet
We can turn the crank around and around and as long as we are aligned to the oil pump, pistons will obviously be in their same place. 1 and it's corresponding cylinder will be at tdc
Now put cams into the picture. With cams aligned to their timing cover dots
Think about this
You can rotate a cam 1 full revolution in your hand out of the car and when you get back to the place you started, the lobes will be back to the place THEY started at. No matter what. This is a solid piece of iron and you can rotate it 360 over and over again and the lobes will never move out of their position. It's not a magical piece of iron
You can rotate it 360 in your hand one time and the lobes will still be in the same place or you can do it 34 times and again, still in the same place
So with that being said you might be wondering if they can be 180 off
Well if they are 180 off then the gears will never line up to their dots behind them because they will be facing down instead of up so obviously the timing isn't right
So think about that. There's no possible way for the cams to be aligned wrong as long as the marks line up. It's physically impossible!
Unless you have the wrong cams, the wrong gears, or you no longer have the factory oil pump mark and rear timing cover marks
That's why the manuals don't cover this problem , because it's not a problem but it's actually just a misconception, mistakes must have been made reassembling and then blame was put to cams being 360 or 180 off even though the marks lined up. But it's impossible. There's no point in taking off valve covers to check which valves are opened and which are closed. It WILL ALWAYS be right if the marks line up
Think about this
