Issues with automatic braking when backing up with a trailer
3.9K views 39 replies 21 participants last post by  Chuck5961
#1 ·
When I back up with a trailer my 25 Frontier it automatically applies the brakes and won't let me backup any further. I apply and let off the brakes and it lets me go a foot or more and then the brakes are applied automatically again.
I turned off all driving aid features(blind spot, lane, forward) in menus and the VDC on the dash. Still does the same thing.
I did a forum search but don't see anything that addresses this specifically.
Any ideas on what may be causing it??
#2 ·
Every time you shift into reverse you have to hit the park sense button below your screen or your truck will freak out and stop rather suddenly. My Titan was the same way. I haven’t gone into the main menu on the speedo screen-maybe you can permanently disable it there.
#6 ·
You can go into the menu and turn off the emergency rear braking. This works until the vehicle is turned off and re-started. I used to push the button, but you have to do that every time you shift in and out of reverse. For me, it's more convenient to turn it off in the menu so it stays off as long as the truck is running. It doesn't take long to turn it off in the menu once you figure out which menu it is.
#22 ·
switch on dash turn it off until you crank truck up again
#26 ·
There is a safety feature designed to prevent drivers from inadvertently backing into an object. There is an on/off button on the center console, under the radio. Turn it off to back when connected w. a trailer or when backing with tailgate down.
