Connecting an LED light and need to find an appropriate electrical ground? The hot lead and fuse holder is pretty short so I want one close to the battery.
See red arrow. Thoughts?
Haha....yeah,...sorry, that picture makes it look like there is some messy wiring on the + terminal, but that is actually the wiring for the LED lights sitting on top temporarily. I just moved them out of the way after running them up there to take the picture of the ground screw location. Thanks for the link...I will be doing something similar, but by using Powerpoles (as I have a bunch of them kicking around from HAM radio stuff). Going to take one main run from the + terminal using a large Anderson Power, and then split that into 3 smaller Powerpole connectors (pigtailed), each fused. Will be doing the same with the ground connector as well.Yes, that's a good ground.
While you are at it, maybe clean up that hot battery terminal tap,
