I dont have the compression ratios on hand nor am I familiar with compression ratios of the 4.0 V6 however, can anyone confirm that our engines are classified in the high compression class? Thank you for any input?
A lot of those HP ratings back then were "net hp", that is, measured at the rear wheels, installed in the vehicle with accessories on. Since that didn't help sales numbers, they reverted back to traditional methods of measuring, with the engine on a stand bolted directly to a dyno, or an engineer's calculation.Lol..compared to a 78 chevy 350, yes its a high compression race engine. I think an 1980 corvette topped out at 180hp.
Net was not measured at the wheels, that's WHP. Gross horsepower was on an engine dyno with no power-robbing accessories installed ( IE no generator / alternator, and no water pump, cooling was by external pump loop, ignition electrical power supplied by an external DC power supply ). Net HP was with all accessories ( including A/C compressor if A/C was available ) installed and operating, and through an exhaust system similar to the vehicle installation including catalytic converter(s) when applicable. The Net numbers were far worse and made the anemic engines of the 1970s look even more downright pathetic.A lot of those HP ratings back then were "net hp", that is, measured at the rear wheels, installed in the vehicle with accessories on. Since that didn't help sales numbers, they reverted back to traditional methods of measuring, with the engine on a stand bolted directly to a dyno, or an engineer's calculation.
Whistler's correct, it is still crank HP. Different implementations of the same engine often have different ratings per platform, whether by intake and / or exhaust design, or internal corp politics ( The Camaro back in the day always was rated lower than the Corvette with the same engine, and the all aluminium twin-turbo V6 that the Fiero was supposed to get was cancelled because it would have been much faster than that model year's fastest Corvette. ) The Grand National and GNX are a whole nother story.The manufacturers listing of hp is still at the crank.
That way, they don’t need to list hp with different models and equipment.
My Dodge is rated 325hp , 600 ft lbs.
Bully Dog added 90hp at the REAR wheel!
Got to be pushing close to 450 at the crank.
