Nope not worth it. Can't fit bigger tires.
Use the search bar, this topic has been covered endlessly on this website.
yup I saw the bushwhacker ones, they are too expensive for me to try and mess with to make work with mine, oh well. ThanksBushwacker is the only manufacturer who makes fender flares for the 2nd Gen. They only work with the steel bumper (unless you modify them to fit the plastic bumper) and are kind of expensive (+$500). You can't reuse the mud flaps without having to modify the flares.
Only you know if it's worth it. It's your wallet that is going to take the hit. With a 2" lift, you're going to need new UCA to avoid CBC. You're also going to need new cam bolts in order to get a proper alignment. All of this stuff adds up fast and you're over a $1000.
As for bigger tires, you don't need a lift for that. Your SV came with 30.5" tall tires. You can run the P4X tire (31.6") and not have an issue.
I agree, it should be 2 inches higher from the factory.Frontier 4x4s sit way to low stock. IMHO, 2” lift is well worth doing. My truck is lifted 2.5” and it makes a big difference Off Road, and I’ve got 31” tires (for now).
Take a look the Firestone airbag thread. They give you extra spring to fix the mushy rear end and are fully adjustable for load conditions. Enjoying them on my Frontier.Frontier work truck owner here:
While my situation of needing something 'better' than the weak factory leaf springs......aftermarket medium duty (or greater) leaf springs WILL lift the back end necessitating a lift of some kind in the front.
They’d sell a lot more of them if they were higher. I’m sure there’s some govt bs reg to prevent that… Off road performance would be much improved as well as aesthetics. The lifted Frontier looks WAY better than stock. The stocker looks like a 4x4 low rider, lol.I agree, it should be 2 inches higher from the factory.
The 2WD and 4x4 trucks have the same suspension. The 2nd gen S on 15" steelies had narrower and slightly shorter tires.Keep in mind that the 4wd suspension is a tad higher (0.5"?) than 2wd coilovers so you can achieve a small lift just by swapping to 4wd parts as well. (got no details of your truck)
That’s not entirely true. The struts off my ‘21 SV 4x4 raised the front of my ‘18 SV 4x2 about an inch.The 2WD and 4x4 trucks have the same suspension. The 2nd gen S on 15" steelies had narrower and slightly shorter tires.
No they don't bubba. Here's your factory service manual that shows you that the spring free height are different, and the wheelarch heights are significantly different. This is very common, in all trucks I've encountered, regardless of brand. Not only is the spring free height nearly a half inch different side by side, it translates to over an inch of height difference on the truck depending on the model. And usually, when you replace tired springs on a 2wd with new 4wd springs, you can gain more than that depending on how saggy yours got.The 2WD and 4x4 trucks have the same suspension. The 2nd gen S on 15" steelies had narrower and slightly shorter tires.
It's probably more of a gas mileage sell? But also, I think older guys are the target audience and the easy driving position/easy entering/exit ergonomics is a key selling feature that the height helps with. Personally, I used to hate the way they look like a van when low, but I was sold when I sat in it and thought "well sh*t, I fit in this thing better than the Tacoma/4runner I wanted (and came from) and it's easy to drive and budget friendly"They’d sell a lot more of them if they were higher. I’m sure there’s some govt bs reg to prevent that… Off road performance would be much improved as well as aesthetics. The lifted Frontier looks WAY better than stock. The stocker looks like a 4x4 low rider, lol.
I dunno, older guys grew up driving trucks that were pretty high off the ground straight from the dealers lot. My old 2000 Taco felt about as high stock as my lifted Frontier. My old Nissan Hardbody trucks felt like the Taco. Took one look at my 2017 Frontier and thought, she’s gotta be lifted…But also, I think older guys are the target audience and the easy driving position/easy entering/exit ergonomics is a key selling feature that the height helps with.
