1 - 15 of 15 Posts
Nissan doesn't recommend changing them until 105K.
Unless you're already running something other than the stock plugs, there's not much point in changing them before then.
More details would help, have you lost power OVERALL, or just in certain ranges? Are you throwing any codes? Are you using really cheap fuel? Have you smelled the exhaust and checked for oil/coolant coming out? I'd pull the plug in cyl #6 and check it out (#6 is the easiest to get to... or was #4... either way.). Do some simple diagnostics before you give up.
· Super Moderator
I did the plugs at 103,000 on both my Pathfinder and last Frontier and all twelve plugs still looked good. I doubt it’s your plugs.
It actually kind of feels like it's sticking in 2nd gear or something ? When I get up to 70 and let off the gas to coast downhill it stays at 3k Rpms. Like it's in a lower gear than it should be?
Is your OD button switched off that's what it sounds like
Your way to high should be at about 2000-2250 somewhere like that and that's with cruising along not coasting if its a 4.0l with the 5sp auto
I changed my spark plugs prob around 70- 80k and that’s only because I installed an IMS and had it all apart. By the looks of the plugs it was unnecessary but still easier to do at the time. If you really feel like there’s a problem, it isn’t that much work to remove everything in your way to check all the plugs.. I even remember someone saying they got to all the plugs without removing anything by using some extensions and swivels... can’t hurt to check, but that mileage is about half life on the plugs
1 - 15 of 15 Posts
