1 - 13 of 13 Posts
Kinda...
I went upstate today to help Drew demod his truck. I think Ill be the last CF member to see it in its entirety. However, the remnants of his truck will last forever in my truck!
damn it, i wanted to come out and help but got stuck helpin a buddy swap a new hub and cv on an eclipse:censor::censor::censor:
and i could have used alot of those parts on my truck. just bad timing again.
so i'm guessing you're having to drive the heep till you actually get the dodge?
Discussion Starter #5
No it's tuned so I get 23hp instead of the regular 20. I installed a synthetic gasket and the chrome helps disapte the heat better. I think it has a high oil pressure blow out valve too!
HA, you guys are killing me.
HOWEVER, you are both wrong, if it says Nismo it's automatically a 10% factor over normal HP figures so 25.3 HP if my math serves me.
Discussion Starter #7
Well either way my truck runs 10x better now and it sounds so much better when I gun it.
B-Rock are you getting one? Ill sell you mine.
haha you all are funny. but as a serious note i would love to have a nismo oil and radiator cap to just dress the ugly engine bay up, nissan should be a shamed of themselves allowing 1000 wires and hoses run all through the engine bay like that.
the radiator cap actually does something- it has a higher psi purge rating than the stock cap... i want to say stock is around 10psi, whereas the nismo cap is around 17psi. i can't remember exactly, and i'm too lazy to look it up. the difference is prettymuch the tension rating on the spring inside the cap.
1 - 13 of 13 Posts
