I've read a bunch of threads on these particular subjects but I figured Id see what you all thought before I take my truck to the dealership.
Up until Sunday, I haven't had any issues with my truck. I stopped at my house to drop off a trailer, shut off the truck and when I went to start it back up, it sounded like it was starving for fuel or air and eventually shut off. Then it wouldn't start at all.
I first checked the fuses and everything is fine. Had gas in truck. Put a scanner on it and it threw no codes. Read about the ecm relay and replaced that. Still no start. Dropped the fuel tank to check the fuel pump and I'm not getting fire to the pump.
Now my engine fan runs when I turn the key on but not start and I have a bunch of abnormal lights on in my dash like my 4x4 light and slid light.
I Just tried the scanner again and it's not even recognizing the system to check it. It sounds like a faulty ipdm but it could also be the ecm. Could even be both...I guess I just need a push in the right direction.
