Hi everyone, I'm scratching my head on this one. Any feedback or suggestions would be great, I'm about to give up and hand it to a shop.
I have a intermittent misfire that occasionally throws a P303/P304 and a blinking MIL. After letting my truck sit for 15-25 minutes my truck will misfire on startup. It will misfire for a minute (MIL is blinking during this) and then run fine. During cold starts there is no issue, only after letting it sit for 15-20 minutes after running it. The only other symptom is a rough idle when the engine is warm. The idle does get progressively rouger after driving and then letting my truck idle.
So far I have tested:
Fuel injector ohms, all are 1ohm over spec. I have pulled the passenger side injectors at idle and the truck did idle rough as expected. Could not access driver side connectors.
There was 4 vacuum hoses that I replaced that were leaking. Can't find any more.
Spark from distributor is very strong
Ignition timing is at 10°
So far I have replaced:
Spark plugs.
Plug wires.
Distributor.
Front 02 sensors.
Cleaned MAF (good values on scanner)
Intake air temperature sensor.
Fuel filter.
The only thing that I could think of at this point would be bad Injectors or a bad fuel pump. I have not been able to test pressure yet but will soon. No excessive oil consumption or coolant loss. I'm honestly lost on this.
And also 02 Frontier, VG33E
Spark plugs.
Plug wires.
Distributor.
Front 02 sensors.
Fuel filter.
