Clips are covering the nuts for the brake light.
Measuring the window, roughly 45½ inches wide at the top (narrowest), about 53 at the bottom (widest) and 13 inches tall in the middle (tallest)
Well aren't you just becoming today's mvp. lol.
I like my lights as high up as possible, so for the rear glass, those two bolts for the third brake light will be utilized with either headliner brackets or some custom fabbed ones. Not sure if I want to do a Feniex Fusion 800 as the window does have a curve to it which will mean that there would be a 1" or more gap between the stick and headliner at the center. The other option is to do a Feniex Fusion 200, which is only 9" long on each top corner of the glass, again hopefully utilizing the third brake light bolts somehow.
I'll be putting red/white Feniex Cannons in the reverse light housings as I think the white reverse override will be brighter than the stock halogen lights.
For the front, just like my xterra, I'll be putting either Feniex Fusion or Apollo red/whites in the grille. Not sure how exactly, as they are different than the xterra's but I'll have to modify the brackets for sure.
