You can actually use the stock location if you want. Remove the horn from the truck, take off the bracket and bend the tab 180* from stock, drill a new hole and bolt it back into it's stock spot. This is what I wound up doing since I was in a hurry and didn't have wire to relocate elsewhere.so where are you guys relocating your horns? i know theres a thread on this.
Don't have one handy, but when I ditched the Volant and installed the INJEN I left the horn the way I had it before. I'll snap a picture when I get home from work and post it up.was able to change order to the standard Volant. Would be interested is seeing a pic of the horn in the stock location but modified Westracing1
whats wrong with the powercores?
The headlight is actually 4 screws for the headlight and 2 for the bumper to allow it slide out. At least for me to get it out.why do you need to remove the headlight? just get a wobbly and an extension and get the bolt to the horns out? these are easy tasks!! and for the headlight should be one or two bolts and a retaining stud deal that pops out under pressure
