Hey folks,
I've got a 2010 SE Frontier Crew Cab *without* the Rockford Fosgate stereo. I want to replace it with a Double Dine after market stereo to get aux, bluetooth, and possibly Sattelite Radio, HD Radio, and nav.
It is a lease however. The dealership said it's totally fine to do, but I just need to make sure that nothing gets cut or changed during the install, and then when I return the truck, i just put back the original stereo.
So, three questions:
1) I was reading another thread where people had done this and showed pictures. In the pictures, wires were cut, soldered together and heat shrink added. Was this necessary or could it have been avoided with the proper wiring harness?
2) I was reading the instructions in the following PDF on how to do the install:
http://www.installer.com/pdf/99-7428b.pdf
On page 8 (numbered 6 in the pdf) it says for Double Din, cut and remove the center bar. What I'm not sure of is whether you are cutting the bar of the new aftermarket mounting bracket, or the original mounting bracket (because I wouldn't want to cut the original due to the lease). Do you know which one?
3) Is there any kind of other cutting or permanent changes that have to be made to the stock vehicle that could cause me issues down the road?
Thanks a ton!
Thanks a ton!
