that sucks. auto zone here has them right next to there LED's.just tried 3 auto part stores in town, no one had it...radio shack didn't have it either, guess i need to order it from ebay
i dont have the FSM right now but all you need is a test light or you can try a interweb search for the FSM.thanks for that info, any idea what color the + wire is?
That would be awesome, but with the little research I've done I don't think we have electronic flashers. I think the only fix is resistors. I was on a xterra forum and they were able to just plug in an aftermarket flasher. I don't think we can.The flasher seems the way to go. I put LED tail lights on my Wrangler and had the fast flash until I got a direct-swap turn signal and emergency flasher made for LED's. There isn't on for Frontiers?
no, your putting the resistor in parallel with the actual LEDI didn't actually read the whole thread so this may be a repeat. But if you have LED lights and put a resistor in series it kind of defeats the purpose doesn't it??
Anyway all you really need is a new flasher designed with LEDs in mind. Here is an example of what I am talking about.
