ok pics of dash kit I will post tomarrow in interior mods. now for the door handels. First open door. Just above the latch mech on the side of the door you will find a rubber gromet inline with the door handel remove this. Now with the right size torx head (20 i think) back the screw out, it is capature inside the bracket so dont worry about droping it in the door panel. now stick your finger in the hole and hold the bracket in place, (once the door handel is out the bracket can fall out between the door and inside panel, found that out the hard way on the first door lol) now remove the rear smaller piece. next pull the door handel about a 1/4 to half way out while pulling backwards with light pressure. It might take a little jimming but go slow and it will come right out. reverse the process make sure the door locks and opens/shuts and you are done. if you have any questions PM me. Sorry to the moderator in advance for this one being so long :wink:
