I looked around, but never really found what I was looking for. So, I made this myself. My 2010 LE had a single 12v charge port with a space above it that looked like another charge port could be installed. I installed a 12v charge port in the dash behind the radio and wired it so it was only on when the ignition switch was on. I then put a splitter in this port so I had 2 ports. I plugged my GPS into one and then routed the wire down through the top tray above the radio. I then plugged a 12v to usb port converter into the other side of the splitter and used a USB extension cord to run to the blank located above the standard 12v port. I removed the blank and cut a hole in it and used a 5 minute epoxy to bond the USB port into the blank. This works great to plug in my ipod or iphone, plus many of the numerous gadgets that used a standard USB plug to charge. Hope this gives some of you ideas. Enjoy.
