1 - 13 of 13 Posts
Remove the glove box. Behind there is a big black box. There are vertical covers (black) there are held on with clips.
Not all models have the filters but the slot to put filters in should be there.
Do you know how tall your opening is? If I do remember right the slot is around 6 in tall and takes two filters (they connect together). Since yours in older 00 I am not sure if they had filters in the model.
It was an option on 4 Cylinder models and standard on 6 Cylinder models IIRC. Mine doesn't have one, but has a spot for one. Your favorite local parts house has the correct part listed for your model in their database :) It was a $15 part where I was gonna get mine, so I didn't worry about it :lol:
My buddy has an '03 XE 4x4 crew cab with no factory installed filter.
I think it's just something for the dealer to try to sell you & keep you coming back for replacements.
In all actuality the filters are a good thing.
1. Because it keeps the condenser fins form getting clogged.
2. If filters the build up of mold and mildew between the fins.
I has animal nesting in my box. With out the filters it would have all been stuck in the fins.
My 01 SE has no filters.
I dropped the glove box down this summer and found there is a place to put the filters but it requires cutting out the plastic cover.
I did a search on this forum earlier and found the info for doing the cutting but have not done it yet.
The space for 2 filters is there, but you have to cut out the plastic cover to access it. The factory did not do it on every Frontier.
Discussion Starter #12
If you find the directions again can you post the thread, I could not find it in the search, thanks
1 - 13 of 13 Posts
