1 - 4 of 4 Posts
Hows it going, bought an 01 frontier in september and loving it. But there are some issues with it.
1)When i bought the truck it had a slight pull to the right. The tires were pretty worn and the dealer said that was the problem(they had re-balanced rotated and re-aligned it). I went and got some new tires on the weekend, but its still pulling to the right (even worse since the tires arent worn the same). I went to get it aligned again but the mechanic explained it wasnt possible because the chamber bolt was seized and that i would probably need a new control arm. What do you think?
2) The service engine soon light is on. I thought maybe for the exhaust, but when the tires were being changed i got under the truck and noticed the gas tank was leaking from the top. I couldnt tell from where. Wondering if anybody else has had the same problem.
thanks Matt
Welcome.
If the camber bolt is seized then the dealer couldn't do an alignment. I'd go inquire about that. The bolts held in place by corrosion.
A slightly draging brake caliper can also make it pull.
1 - 4 of 4 Posts
