So the Gen 2 Frontier is long overdue for a makeover. If you were in charge of engineering, what would you do for the next gen Frontier? What would your goals be?
Here's what I would do.
Engine- a Direct-injected version of the VQ35 would replace the VQ40 for fuel economy, size, and weight reasons. With proper tuning it should have more HP and torque than the outgoing engine.
Transmission- options are a 7-speed dual-clutch auto or 6 speed manual.
Body- the whole truck is scaled down very slighlty for more trim proportions. Increased Cd and better approach and departure angles. A new bumper is designed with an integrated trailer hitch reciever. Better turning radius (if possible). LED daytime running lights.
Suspension- the front suspension should be redesigned to provide more wheel travel, but still provide a smooth ride.
Ground clearance- increased slightly overall.
Tires- no more Long Trails and Rugged Trails, Firestone Destination A/T is the current standard tire for 4wd models.
Front diff- a new more robust front diff design.
Interior- bluetooth connectivity and an 8" touchscreen are available. Dual USB ports and dual 12v aux outlets. Info display in instrument cluster between tach and speedo.
Weight- the previous truck is too heavy. Current goal would be to reduce the weight of every model/package by 10% over current. This could be accomplished by using some aluminum instead of steel, a composite bed, etc. Lower weight means better fuel economy too. This would be a huge challenge to provide the strength and capability with less. But look at what Mazda was able to accomplish with Skyactiv on the 6.
Any ideas you have?
I think going forward fuel economy is the biggest challenge and the greatest need, as well as modernizing some safety and convenience features.
Any ideas you have?
