took the truck in because I was getting this weird floating sensation in the steering wheel when i would go over bumps. It felt a little like the wheels weren't on the ground. the truck would also dance around a bit on the highway as if it were windy out. Mechanic said Idler arm was bad and it needed to be replaced. Now do I need to replace the entire arm or just the bushings? Do the arms themselves wear out? I have never had the arm hit anything so i don't think it got damaged but I don't know if these things have a lifespan or if they are a non-wear item? Do these symptoms sound like idler arm issues to anyone?
thanks in advance
thanks in advance
