1 - 17 of 17 Posts
And what really blew me away is the thing drank almost an entire gallon!!!
· Super Moderator
Wonderful thing ain't it!
I really really appreciate it during the salty months of winter around here.
Mine has never lit up. I can see it in the cluster and have run it dry multiply times. Too much effort to remove the fender liner to find out if its just not hooked up. Usually go through 2 gallons over the winter so i try to start with it full and check it around january or feb.
The owners manual for my '13, on page 10, WARNING/INDICATOR Lights says "Low windshieldwasher fluid warning light (if so equipped)" but says nothing about which models are so equipped. I'm not sure if mine is cause I've never actually run out.
· Super Moderator
For those who have it does it illuminate when you turn the key and the dash lights turn on?
· Super Moderator
Mine (which I know works because I've ran it low), never illuminates under any test conditions, (initial ignition on or cranking). It only illuminates when fluid is low.
My '06 has one and it illuminated the very first time in the parking garage at the airport, upon arriving home with the family at 2AM.
I was tired, my eyes were bleary and I thought, "Really?! What the ^&@ is that?"
1 - 17 of 17 Posts
