I want to go wider not taller.
1899 Views 4 Replies 5 Participants Last post by  anoxion
Guys I appoligize up front because I dont have time to search the forums like I should, please be gentle with me. Just like my title reads. I want to go wider with my wheels and tires. What are my options? I dont want to put a huge lift but im not opposed to putting a small spacer lift or something. Is anyone offering a 15" steel wheel for the 07's? I would like to put some All terrain 50's on my SE 4x4.
Thanks in advance,
GutWrench
with the 2nd gen frontiers you can't go smaller then a 16 inch wheel because of the disk brake size. If you want to go wider you can swap the titan control arms and push the front out 1.5" per side. Also you gain some wheel travel.
looks like stock you are 265/70R16 10.5 wide and 30.6" tall
the width of the tire is going to depend alot on the width of your rim and without getting a wider wheel I dont think your going to have much luck with an AT tire that will get you much more then 11" wide.My wheels are 9" wide and the tires 12.5" wide and I couldnt do any wider without major rubbing unless I use a wheel spacer then it would push the wheels out to far for me and look "ricer"
Not sure where you live but you might try more of an allseason tire
I Will Be Running Bfg/km2's 305/70/16 On The Factory Nismo Wheel 16x7 And Ive Already Test Fit Them And Drove Without Issue. It Is The Same Diam As The Bfg/at 285/75/16 I Had On There, Only .9" Wider
i like this idea. next set of tires is gonna be that size.
