How is a replacement not going to solve the problem?
How is a replacement not going to solve the problem?A replacement OEM radiator will not solve the problem, a custom or aftermarket or titan radiator might solve the problem.
well if the problem has been identified by nissan,and you buy it from them,How is a replacement not going to solve the problem?
This would assume that Nissan hasn't done anything to address the problem. Has anyone inspected a recently manufactured radiator to check or is that even possible?The reason i say OEM will not fix the problem, is becasue the failure is in the seam between the radiator and the trans cooler afixed below it. (I) wouldnt buy another "Cookie cutter" radiator (one that they have a OEM design for and pump them out like rabbits) beacue it would be prone to the same failure (unless otherwise stated)
