1 - 8 of 8 Posts
I need to talk to someone who owns or has owned a first gen fronty 2.4L, standard trans. For some reason the truck won't start. Battery, starter, alternator, everything like that works fine. I push in the clutch and it doesn't start when ignition is turned. I'm getting full electrical power. PLZ HELP ME?
Spray in some aerosol starting fluid into the air cleaner. Push down pedal, try to start, try a few times. If it's spinning the engine OK, this should help isolate whether your issue is spark-related or fuel related.
Another help for your vehicle with spark plug wires would be an inexpensive spark plug tester, goes inline with a plug wire, look for sparking.
It doesn't click, turn over or anything. All the interior lights and radio come on. Yesterday afternoon the check engine light came on. Diagnostics said it was EGR valve. It just won't start now
1 - 8 of 8 Posts
