First 4X4, so of course I drive through all the mud. After cleaning the exterior a good bit I noticed some mud hanging down underneath the truck. I got under there twice with a power washer and cleared out probably 40-50lbs of caked on mud.
About 2 weeks later I began to notice a clunk in the front end. I couldn't repeat it in any circumstance, but it was there. I put the front end on jack stands, removed the front two wheels and inspected everything I could find. Nothing was lose or bent, etc. There was, however, a TON of mud caked on everything. I figured some of the larger chunks are probably moving around causing the noise. So I power washed the begeesus out of the front end again. About 20lbs more mud came out.
Now I have a terrible wheel bearing noise. I know there is probably mud and or no more grease in them from the power washing (dumb mistake).
My question is what can I do to fix it?
- Repack the current bearings
- Replace the bearings
- Replace the hub assembly
It seems like Rockauto sells the bearings, but I have no clue how to remove them from the hub. I don't see any info on that on the forums.
TIA for any assistance.
