1 - 8 of 8 Posts
I have the PRG spacer lift now but I've been wanting to go higher since I need a new set of tires. I'm looking for a lift that won't break the bank. I won't be doing any serious off road in. So this is mostly for the looks. What kind should I get? Pros/cons?
I have a 2005 LE Crew Cab 4x4. Thanks for that link, I like the sound of the titan swap, but that seems like a hassle to find parts. I think I'd prefer a kit that comes with everything at once.
I'm liking the Calmini 5" lif kit over the Fab tech 6", mainly because Fab tech wants you to cut sections of your frame off. I'd rather not do that.
Does anyone know of you will still be able to tow heavy loads with these lift kits? I have a 3500 lbs. Trailer that I'd still want to tow with the truck afterwards.
Rogue Admin
2007 LE 4x4 Crew Cab Long Box
You can tow, you will probably need a drop hitch and possibly airbags in the rear to prevent sag - depending on what you do with the rear springs.
Gone but not forgotten Member
That kit comes with rear blocks and shackles for the rear. Not sure how well it would tow.
1 - 8 of 8 Posts
