1 - 3 of 3 Posts
Hi, just wondering if anyone knows any tricks to tighten side mirror glass?My drivers side mirror glass shakes like crazy.Thanks,Rod.
You might want to create a signature for your posts to let people know what kind of truck you have since that may matter in answering your question.
For a 2nd gen power mirror it's held on by 4 hooks, so possibly one of more of the hooks aren't hooked in. Angle the mirror fully up and then pull from the bottom to disengage the clips. Continue to pivot the mirror upward from the bottom to separate the hooks. Re-installation os the reverse of the steps I've listed.
For a non-power mirror, it looks like there are 3 threaded screws from the mirror through the door frame. You'd need to remove the inner door panel to be able to tighten the nuts.
1 - 3 of 3 Posts
