1 - 4 of 4 Posts
get your hand behind it and push forward if I remember right. pop the radio and climate control bezel off and then you should be able to reach it. I have pictures of it somewhere.
Ok, you might have to pull some of the plastic away from it from the back. Here is the best picture I can find of the part you are removing and what the part it comes out of looks like
Thanks for the quick reply.
Not sure how to get behind it?
I added a photo above.
The easiest way to gain access to the rear of that panel I would say is to pop off the top tray (above the head unit), remove the screws and pop the entire center area out. Then you can reach behind the radio and HVAC controls and pop it loose.
1 - 4 of 4 Posts
