4x4 frontier. In manual it says to just swap the left rear left front. same on right side. But my auto tech says i should be moving rears to front, and front crisscrossed to rear...
what do i do?
what do i do?
Yes...I heard once if you run radials one way you should not then turn and run the other/or criss cross.
Anyone else heard this?
X2 and nobody seems to understand this. Even Discount Tire...It says really big on the outside of my tires "This side goes on the outside" so what does the tech do? Puts that side on the inside! I rotate front to back, back to front thats it.I think the manual says to just move front to rear but keep them on the same side of the truck because many tires these days are directional and if you move them to the other side of the car they'll be backwards. I just did what the manual said and after 30k miles the tires are wearing evenly.
;-p hahaha... good advice. I will add though that i had the factory tires on my truck for over 50,000 miles and had no problems using the method that i stated earlier.just don't rotate them anymore... drive 'em till they rot off.... or blow off... then replace them... make sure to wheel with them after the wearbar is no longer there and they look like drag slicks...
