This write up is for the 05-08 CC Frontier with rear defroster option. I don’t know if those without the rear defroster will have the wires for the defrost button. If someone wants to check and take some pics I will gladly add that to this write up.
I found that Nissan has 2 different sets of heated mirrors you can use. I am using one of each in mine and both are working fine. RH: 96365-EA16A LH: 96366-EA00A.
These mirrors are less expensive but you’ll have to cut away the paper to get to the Terminals. LH: 96366-EA00A $17.65 from www.CourtesyNissan.com RH: 96365-EA00A RH Comes in as a NON-Heated Mirror. Do Not Order
If you don’t feel comfortable with the mirrors above then you can order these for twice as much. LH 96366-EA16A $35.02 from www.CourtesyNissan.com
RH: 96365-EA16A $32.70 from www.CourtesyNissan.com
I am using 18 AWG with 1/64” insulation. You don’t want to go much thicker than that or you may find it difficult to pull the wire through the mirror assembly.
I started with about 6 ft (per side) of red and black wire and used electrical tape to add some extra protection to the wires. You may or may not want to do this. Up to you. It also makes it a little easier to feed the wires through in some places.
***I highly recommend verifying the wires are correct before cutting them. My wire colors may be different than the colors in your wiring harness***
The first thing you should do is check to see if you have the relay and fuse installed for the heated mirrors.
If you have the relay and the fuse you’re ready to check your wiring harness for 12VDC.
Remove the panels so you can get to wire harness.
Remove the connector and check for battery voltage from the blue (power) to ground. Diver side is a light blue and passenger side is a dark blue.
Turn the key to the on position and press the window defrost button.
With a multi-meter or voltage checker put one lead to the power wire and the other to ground.
You should have close to 12VDC here.
If battery voltage is present, you are ready for the rest of the install.
Pull the white plastic back so you can disconnect the mirror wiring harness.
Remove the plastic clips and pull off the plastic cover.
Use a 10mm socket to remove the 3 nuts holding the mirror assembly to the door. After the 10mm nuts have been removed the mirror is disconnected from the door so hold on to it or it could fall off
On the bottom of the mirror you’ll have to lift up some tape to reveal 3 torx bolts. Use a T-25 to remove them.
Once the torx bolts have been removed you can pull apart the assembly. This will make it easier to feed the wire through as shown below.
I left about 6 inches in the mirror and reassembled the mirror. Strip the insulation and crimp on the Quick Disconnects. I am using 3/16” female connectors.
Did you find that M8 connector and M75 were already plugged to something? Picture on M8 is not clear, M75 shows it is already plugged to a connector. Do you know what it feeds?
Service Manual shows M8 connects to D2 for door heated mirrors on driver side. M75 to D101 on passenger side. Without heated mirrors these should be unused?
I wanted to follow your instructions, but purchase the door harness so it should just plug into M8 and M75. Haven't taken the panels off yet, but obviously you have!
good job, be careful though, you about to be voted the official how to thread and pic member. I like the add in arrows and tagging. Now you need to do a thread on this as well, that is unless you want to do all the install guides...........:goodjob: Iam glad you posted part number I went down to Nissan today and they didn't have but 1 part number for mirror glass and we pulled off the shelf and they were not heated(nor hidden) even using Sean's vin.
I used to work in manufacturing where one of the things I did was to write tech documents. So I think that helped in giving me an idea on how to write this up. I was getting a headache toward the end of it so if anything seems unclear just send me a PM.
hah! I knew it! I used to work in R&D for a computer company so I have seen lots and lots of engineering change orders. Most of them were *not* as well written as yours.
this is a great mod, I will put it on my list. thanks!
Impressive Write up and pics, Congrats, you get post of the year in my book, and I already have the heated mirrors.
When are you going to do the 2* timing advance and write up?
and lets not forget rain sensing wipers, you do realise thats exactly how this mod got started......and finished
Again good job, youre now the
C.F.O.H.T.T.P.
CLUB FRONTIER OFFICIAL HOW TO THREAD POSTER
congradulations on your new "OFFICIAL" position
uh sorry no additional pay, but then you new that already didn't you!!!
youre now the C.F.O.H.T.T.P.
i have a question though. i have an LE and was told by a Nissan dealer that all frontiers have the same glass. Having an LE with the option of heated mirrors, the terminal should already be there according to this parts guy. he said all i would need to do is run the wires. any insight on that?
Today I checked out the LH 96366-EA00A the local dealer ordered in for me and it does not have the terminals under the paper. Supplier must be back to making them without.
So If you want the heated glass you must order the glass from the Pathy parts breakdown. That's what my parts guy said the other number was for. List price was over $55.
No not all the glass is the same. I have seen 3 different versions. You can look at my first post and see 2 of the heated versions and the third is the non-heated one. They all have the same dimensions and they all connect to the actuator the same way though.
So you have an LE without the heated seat/mirror option?
I KNOW YOU DIDN'T WANT TO READ THE INSTALL, BUT A SIMPLE YES, UNLESS YOU BUY THE COMPLETED MIRROR ASSEMBLIES THAT ARE PREWIRED THEN ITS PLUG N PLAY AND INSTALL A RELAY AND FUSE IF NEEDED IN CORRECT FUSE BOX LOCATION.
SEE C.F.O.H.T.T.P. FOR ALL THE LASTEST AND GREATEST INFO WITH PICS FOR THOSE OF US HARD OF READING AND HEARING ON HERE.
113.3K members
