and lets not forget rain sensing wipers, you do realise thats exactly how this mod got started......and finished
Again good job, youre now the
C.F.O.H.T.T.P.
CLUB FRONTIER OFFICIAL HOW TO THREAD POSTER
congradulations on your new "OFFICIAL" position
uh sorry no additional pay, but then you new that already didn't you!!!
youre now the C.F.O.H.T.T.P.
i have a question though. i have an LE and was told by a Nissan dealer that all frontiers have the same glass. Having an LE with the option of heated mirrors, the terminal should already be there according to this parts guy. he said all i would need to do is run the wires. any insight on that?
No not all the glass is the same. I have seen 3 different versions. You can look at my first post and see 2 of the heated versions and the third is the non-heated one. They all have the same dimensions and they all connect to the actuator the same way though.
So you have an LE without the heated seat/mirror option?
I KNOW YOU DIDN'T WANT TO READ THE INSTALL, BUT A SIMPLE YES, UNLESS YOU BUY THE COMPLETED MIRROR ASSEMBLIES THAT ARE PREWIRED THEN ITS PLUG N PLAY AND INSTALL A RELAY AND FUSE IF NEEDED IN CORRECT FUSE BOX LOCATION.
SEE C.F.O.H.T.T.P. FOR ALL THE LASTEST AND GREATEST INFO WITH PICS FOR THOSE OF US HARD OF READING AND HEARING ON HERE.
It appears that part # 96365-EA00A (Pass Side) does not have the heating element installed. Part 96366-EA00A (Drivers Side) has the element but it is covered up.
So it looks like people need to order 96366-EA00A and 96365-EA16A OR 96366-EA16A and 96365-EA16A.
I'm guessing that Nissan or the part supplier ran out of the standard driver side mirror glass and just started covering up the element on the heated version and started selling it as the standard version.
Thanks for the info. I only saw the RH (96365-EA00A) for a few minutes. I thought it had the same covered terminals as the LH one did. At that time I didn't know they were covered up so I could have missed that. I'll make an update on the write up.
You could add a toggle switch in the dash. All that is needed is 12v to heat them up. I would make sure that the switch had a timer or turnned off with the ignition so you do not leave them on.
If you really want them you could check to see if the wires for the switch are there. You might get lucky with that. I've read on other posts where the wires for other switches were there. (ie. Hill descent control switch) So you won't know until you check.
Nobody with a KC has stepped up to check for those wires yet. If you do, let us know what ya find.
GolfTango said that he would check his wiring. I haven't seen him report his findings yet.
I took mine apart a little while ago. The main wiring for the controls are in the 26 pin harness (M49) at the top of the controller. I don't know how many cavities are vacant because I did not unplug it.
