I am going to do a drain and fill on the transmission and replace the transfer case fluid and also the front and rear diffs. I just bought the truck and it is a 07 LE crew cab 4x4 with 63,000 miles. I can't find the capacities of the front and rear diffs. I would like advice on what fluids you guys are using to replace the factory fluid in each of these areas.
Thanks,
David
Thanks,
David
