When the truck is idling there is a constant "ticking" sound that (based on research) is either the injectors, or some type of piston/valve slap. Heck, it might not be any of those and may be something on the belt clicking as it spins...It's not too loud, but I just hate hearing it. I don't thing it is a mechanical malfunction as the truck runs great from what I can tell.
Anyways, I want to try and figure out what is causing the noise, and hopefully make it stop so the truck idles nicer. Any guidance is appreciated. I dumped a bottle of Lucas Upper Cylinder Lubricant / Fuel Injector Cleaner in it when I filled up earlier, not that I am expecting a miracle or anything though...
There also seems to be a roaring wind noise when the RPMs increase. I am thinking my fan clutch might be bad causing it to spin with the RPMs. I'm going to watch the fan at idle tonight and see if it disengages at all.
