The outer edges of the front tires are showing accelerated wear. They have just over 3k miles on them, and the outer tread blocks are almost worn down to the secondary ridge on the duratrac, which i'm not too happy about--need to get them rotated--the rears still look new.
I hope I'm reading this correctly, it's very small on my computer... but it looks to me as follows.
Driver Pass
Caster 2.72° 2.18° -Looks good, should be slight floaty-ness to the steering and oversize tires may hit the body in full-lock situations.
Camber 1.31° .90° -Too much positivity lol, may feel a bit unsure in the corners, negative camber give a more planted feeling... but flat may be the best for tire wear -maybe- ask your tech.
Toe 1/8th translates to .125°, which is good and should help the truck track straight
If I understand, the Camber is set at 1.31°, and .90° positive... this will certainly give you edge wear. Some negative camber is beneficial, positive however, not so much. The alignment shop probably wanted to get closer to 0.0°-0.5° positive.
Is the truck kinda twitchy and hard to keep straight on the highway? Maybe a bit sloppy through curves?
