so i starting making these a while back and had to redo the mounting legs. they were to close to the pinch weld and during flex they were rubbing. here is a few pics of the redone sliders and where i mounted them.
mounted the same way shrockworks....
(not in pic but rear mount left/bottom hole is drilled out and bolt and nut installed)
all welded up and painted with bed liner....
here they are on the truck....
only have the drivers side finished up still working on the pass side.
