Anyone know how similar the Pathfinder's frame at the back was in the years when they shared a lot in common with the Frontier? Someone local has a hitch for cheap and I'm curious if it'll bolt on if the rear bumper were removed.
I can't think of any way to achieve that unless you either weld a custom receiver to the frame, at the same level as the frame, and then put a hole in the bumper reinforcement and cover; or move your bumper down.Yeah, I was referring to the 2005-2012 Pathfinder, the R51 chassis. From the B-pillar forward from all outward appearances they're identical to the D40 truck.
My idea was basically to have the 2" receiver hidden behind the license plate, so that it doesn't hang-down at all, or for the license plate to be off to one side or the other. This is most cost-effectively achieved if one of the SUV hitches, already designed to be concealed within the cosmetic bumper, also fits the frame of the D40 Frontier.
It looks like, again from outward appearances, that the Frontier, Xterra, and Pathfinder where based on the F-alphas chassis, are substantially the same mechanically from the trailing edge of the front doors to the front of the vehicle, with the Xterra having mostly cosmetic differences but with the same hardpoints, and many of the aftermarket parts are known to fit both the Xterras and the Frontiers. It's a little less clear once one gets to the back where one has a truck-body versus a wagon-body though.
