Getting back to your question about tire sizes.
Mertic tires first number tread width/contact patch, second number aspect ratio, letter speed rating, third number rim size. You'll have to convert the first 2 numbers to inches to figure sizes in the Cooper tires. Once you have the circumference of the two tires you can figure out the ratio/percentage of speed difference. Divide the larger number by the smaller, subtract 1 and multiply by 60 (or whatever speed you drive at) and this will tell you the speedometer variance.
2.54 centimeters to the inch.
pi = 3.14 inches
d = diameter (rim size + (2 x sidewall)
treadwidth x aspect ratio = sidewall
c = circumference
pi x d = c
3.14 x d = c
3.14 x (rim size + (2 x sidewall) = c
As long as you do the math the same way for both tires the variance won't change. I like you was wanting more efficiency, though I'm not quite a zealous as you are. I use my truck as a work truck. The Cooper/Mastercraft tires are the same for dealer comparison/price. You may find one dealer near you and not the other, the tires are the same just a different name embossed on the side.
pi = 3.14 inches
c = circumference
pi x d = c
3.14 x d = c
