1 - 2 of 2 Posts
Does anyone know if a high volume oil pump is available for a GEN one Nissan frontier 2003 in particular, and if so where can I buy it?
Generally speaking, "no," as far I am aware. The oil pump from a Z31 300ZX turbo w/ AT has the best volume rate of any stock VG-SOHC engine. The problem is that the end of the crank (where the crank pulley bolts to) are different sizes, so the crank would have to be swapped out with the older-style VG30 crank and crank pulley. I think the timing belt covers and water pump have to be swapped, as well. There may be more to it, but that's all I remember. It's not a simple oil pump swap..which really isn't all that simple to begin with!
1 - 2 of 2 Posts
