1 - 7 of 7 Posts
Where i just my hids from DDM and i dont know if i got everything. So heres the picture:
so i got the 2 ballast that's on the very top, the 2 hi/low 9007 bulbs on the very right, but i dont know if that's the hi/low controller or the relay that i also ordered. Please lmk because i really wanna installed these but im not to sure if i got everything. thanks.
I have the 55 watt kit.
The instructions are poorly written.
The box with the heat sinks is for the high/low control and has a relay to route power directly from the battery to the HV transformers.
Before you seat the 3 wires in the blue, OEM to HID adapter, test for proper operation by inserting the pins in different locations (high, low and ground). I went by the pictures from the .PDF I downloaded and its was not correct. (Just noticed they are already installed)
Ensure you have a good connection to the positive terminal and ground, mine had heat shrink covering a portion of the contact area of the terminal rings.
I literally JUST ordered these from DDM, can't wait to put 'em in. I just got excited cause I ordered mine but can't really help by saying you have everything, it looks like you do based of the pics on their website though.
Best I can tell everything is there. I put 55W hi/low 9007's in my frontier with the auxiliary power harness as well as a 35W H7 set in my bike. It looks like you have all you need.
Here's my plug set up.
I need to apply potting compound to seal it.
When i look at my stock headlight harness the black wire is in the middle. Is it because were different years? im not to sure. Oh yeah how the hell do you take the pins out of the blue connector? Im having the hardess time taking it out because my wires are backwards. My high is low and vice versa. PLease need some tips to get it out. Thanks in advance
I've been running my DDM Tuning kit for about 5 months now and absolutely love them, huge difference over stock even though they are only the 35 watt kit. I did headlights and fogs, I also have the 35 watt kit on my 09 Civic SI for the headlights and fogs. I will never go back to normal bulbs again. I just ordered some for my Polaris Sportsman and the Scrambler yesterday LOL
1 - 7 of 7 Posts
