Anybody use the stock headlamp retainer ring on their HID install? (The white plastic ring that holds the stock bulb in)
I have the DDM BiXenon. I am going to get a couple clips and dremel the edge tuse the clips. I feel better as you stated to have them snug.It will depend on the kit you have. Some brands of HID bulbs will fit slightly different than stock, not allowing you to tighten down the retainer ring. All of the HID bulbs i've used have had a slight variation in how they fit the headlight socket. If possible, try to use that ring...it will help your bulbs stay snug and not bounce around when you run over potholes or bumps in the road. If the ring won't fit over, just make sure the bulbs are snug and won't fall out.
Two things either you don't have a Bi-Xenon version or DDM has changed their bulbs in the Bi-Xenon. (Another member "Nissanpowerbaby" experienced the same issue lately)there is NO modification needed if you use the DDM kit. I can't speak for the other kits though.
