1 - 3 of 3 Posts
Ok, I know my way around a multimeter and wiring. I have installed a hi/lo beam kit on my 06 frontier. The high beam never works. Heres the thing. If I put it in high beam and touch the opposite side to ground the high beams come on. The positive connection goes to the battery as does the ground for the passenger side light. I grounded the driver light to the metal behind the light , after buffing the paint off. If I switch the pins in the aftermarket harness it changes nothing. I am at a total loss here and feel like I'm missing something. Its a 6k kit if it matters. Any input would be appreciated.
Thanks
Rick
I have a set on my truck as well and i ran into the same thing. Let me see if i can take a picture of the wiring so maybe you can give it a shot the way i did it. Hold on.
The blue connector is the one from the hi/low HID kit. I had to mess with them until I found this configuration that made the lights work.
At first I only had high beams and no lows.
I hope this helps.
1 - 3 of 3 Posts
