1 - 9 of 9 Posts
Im new to the forum and to Nissan frontiers as well. I have a question about my new truck. It was a gift. 2007 nissan frontier 4.0l le 4x4 102k. It does start but has a constant putter and no power. I got underneath and checked the exhaust and both cats have EXPLODED. Can I replace them my self?
Rusted out or detonated??
Any codes?
They look like theey have been filleted. And its the front two. Im am getting 2 codes the multiply random misfire, and fuel level sensor high
Firstly... WOW! THat's an awesome gift! Secondly... WOW! BLOWN CATS!?!? That's a new one for me. Best of luck to you.
Fix your upstream problems as they may have contributed to your cat issue(s).
Second on the sentiment that you've got an awesome gift! I wish someone would throw gifts like that my way more often too! Haha! But honestly, if you find you have a bit of cash to get the vehicle done up properly since you're only just having a new go at it, get it down up and checked thoroughly at a shop so that it's fully road worthy right off the bad. Good luck and welcome to the club!
You have an issue with the ignition or fuel system. Excess fuel will ruin the catalyst. As stated fix those issues first.
There are 4 cats on a VQ40. The primary cats are monitored by the ECU. The secondaries can be replaced with "off road / race use" B pipes without triggering a check engine light.
You can get aftermarket bolt direct on replacements for a fraction of the cost compared to OEM. The quality is no where near as nice and I am skeptical of their life span. I replaced one of my primaries with a Walker replacement. Fitment was fine. The job is not all that hard if you have the tools an know how. Get metal gaskets no matter what.
Ok well my plan was to take the cats off and replace the plugs and crank it to see if it levels out. I was told that it drove for 2 hours towing a car until its started having issues. It was sitting for 6 months prior to this.
I will also drop the gas tank and try to replace the fuel sensor and or fuel pump
1 - 9 of 9 Posts
