1 - 15 of 15 Posts
got 2.5 inch coil spacers from andy
a 2 inch block from prg
added a 2 inch body lift and some bfg not real 33's (285/75 R16)
made something to hide the rear bumper gap
and rock rails from shrockworks
might put some upper control arms on to stop the coil bucket contact .... do uca's lengthen travel much?
Nice Job! looks clean
Looks much better than stock! I'm hoping to add the 2" body lift in the fall with 1.25 wheel spacers. Did you make your body lift or did you buy?
nice job
yep I agree. looks great. wheel spacer maybe?!?!
hey looks good :goodjob: get much rubbing with the tyres?
PRG UCA's give you approximately 1"-1.5" of extra droop and has a built in bump stop so you don't get metal to metal at full droop. There are a few write ups on doing the bump stop mod to stock UCA's (I have it) which works pretty good.
Your truck looks great, I can't decide if I should go with a 2" or 3" Body Lift with my next set of tires.
Do you have enough clearance with the 2"BL?? I want absolutely no rubbing.
Discussion Starter · #12 · (Edited)
sorry about the long awaited reply, the body lift was bought, im kinda lazy and that way i could ask for it as a gift.
sorry about the long awaited reply, i live in fayetteville for the time. i plan to move to the raleigh durham area in less then a year, hope to get a job in RTP after i graduate this december. cant wait to get away from ft. bragg, i was stationed there for five years and got stuck here another three because i decided to go to school.
Discussion Starter · #13 ·
thanks for all the great comments guys, a few of you asked about tire clearance/ rubbing issues... well i have not changed anything and have no rubbing with the 2.5 inch spacers and the 2 inch blocks and 2 inch body lift, i highly recommend the same set up if you are considering it. as for the comments about the wheel spacers, im totally with you, it would look alot more aggressive with the tires 1.5 inch further out. i plan to get some new wheels in the future, at the time i needed new tires and couldnt afford the wheels as well, so ill get them in a year hopefully
Thank you for posting this! I've wondered for a long time what my truck would look like with a 2" BL. I haven't seen another silver nismo crew like ours on CF that has all the same OEM options. This helped me greatly.
2020 SV Nissan Frontier Crew Cab Long Bed
Come out with like a small black I beam (Powder coated) between the bottom of the tail Gate and the bumper. Then silicon the top and bottom of the I beam with dual LED lights (top and bottom Dual ) just like a tail gate LED`s LOL don't know but would probably look pretty good .
1 - 15 of 15 Posts
